Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
drop it
Old Mar 17, 2007 | 11:12 PM
xtreme_ss's Avatar
xtreme_ss is an unknown quantity at this point
Default drop it
I have two questions, first I dropped my rear 2 inches, and I want to drop my front an inch to level it, could I cut the coil springs? Second does anyone know if 04 extremes have torsion bars?
Old Mar 18, 2007 | 01:06 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: drop it
dont cut your springs....... cut springs = crappy ride. . . . no they shouldnt have torsion bars... thats the 4x4 suspension... it should be coils...
Old Mar 18, 2007 | 04:49 PM
xtreme_ss's Avatar
Default RE: drop it
what would anyone suggest I do for the front
Old Mar 18, 2007 | 05:23 PM
a_tack's Avatar
Default RE: drop it
buy new springs..... search the internet for lowering kits... .you would be amazed at what you can find for your truck. .
Old Mar 18, 2007 | 10:42 PM
a_tack's Avatar
Default RE: drop it
I was sitting here reading a JC Whitney catalog and found something you might be interested in.... If you don't want to buy new springs, for around $22 a company called Hellwig makes these spring compressors... http://www.jcwhitney.com/autoparts/S...searchbtn.y=15
Old Mar 18, 2007 | 11:19 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: drop it
That would be a real crappy ride too. Get springs or spindles. Spindles would be your best bet it you want 2". They won't affect your ride quality at all. Don't forget to align it after.
Old Mar 19, 2007 | 02:03 AM
xtreme_ss's Avatar
Default RE: drop it
correct me if Im wrong but if I buy 2 inch drop coils, then I will get a 1/2 inch drop being that the extreme blazers sit 1.5 inches lower than a stock one right
Old Mar 19, 2007 | 10:09 AM
LORCLAS's Avatar
LORCLAS is an unknown quantity at this point
Default RE: drop it
You should get a 2" drop compared to what you have now. Do not compare the drop to a stock Blazer if you already have an Xtreme.
Old Mar 19, 2007 | 04:02 PM
xtreme_ss's Avatar
Default RE: drop it
Sorry I have a 04 extreme so a 2 inch drop coil will give me a half inch drop right
Old Mar 19, 2007 | 04:11 PM
a_tack's Avatar
Default RE: drop it
I think they're sayinga 2 inch drop coil made for an extreme will give you 2 inches of drop...
