Extreme ZQ8 suspension
I was wondering if any one knew if the Extreme ZQ8 suspension would fit in a 98 s-10 blazer 4-door 2wd 4.3? also if so what would be the difference in heights. and what exactly is different from the two? from what I was told it is like a 1.5 inch difference in the front springs and different leafs for the back.
thanks |
RE: Extreme ZQ8 suspension
Should fit just fine. IIRC, your number sounds correct. The differences are in the spring length and rate as well as the sway bars.
