-   Lowering Tech (https://blazerforum.com/forum/lowering-tech-45/)
-   -   may lower 1-2in (https://blazerforum.com/forum/lowering-tech-45/may-lower-1-2in-11656/)
EuroGoldLS Jul 5, 2007 11:12 PM
may lower 1-2in
I'm thinking about lowering Jenn about an inch or two. My question is, is there an easy way to lower a 2wd like adjusting the t-bars on a 4wd?
PS. I hate screwing around with coils.
swartlkk Jul 6, 2007 06:39 AM
RE: may lower 1-2in
Lowering spindles, lowering springs, block for the rear axle... There should be a bunch of options out there...
FFJustin99Chevy Jul 6, 2007 06:45 AM
RE: may lower 1-2in
Why go down? Put Jenn up in the air. I'm sure she would enjoy a better view up there.
EuroGoldLS Jul 6, 2007 07:33 AM
RE: may lower 1-2in
She is 2wd... pointless to lift... If I do anything, she's gonna go low...
myol blue4x4 Jul 6, 2007 09:29 PM
RE: may lower 1-2in
The easist would probably be to lower the tbar and get lowering shackles.
lastcoupe Jul 6, 2007 10:01 PM
RE: may lower 1-2in
Nope..2WD's don't have torsion bars....drop spindles is the best way for the front, you won't suffer any loss in ride quality that way.Blocks for the rear are sufficient for a 2 inch drop.
myol blue4x4 Jul 6, 2007 10:05 PM
RE: may lower 1-2in
Oops my bad, Yeah spindles would'nt sacrifice ball joint wear so in general it would be better but unfotunately cost more.
LORCLAS Jul 12, 2007 07:17 AM
RE: may lower 1-2in
Spindles are the most expensive part of the drop. About $300. Springs and drop blocks are not too expensive. Probably need drop shocks too. Not sure on a 4-door.
blazinloud Jul 21, 2007 12:06 AM
RE: may lower 1-2in
leave it at stock height then.........it isnt a honda
