Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Spindle question
Old Nov 24, 2009 | 02:28 PM
burt's Avatar
burt is an unknown quantity at this point
Default Spindle question
Okay I got a '98 2wd 4dr and will be ordering a Belltech 3/4 drop with 2" spindles and 1" coils up front and of course 4" blocks in the rear. I am planning on doing the drop myself with some help from a few mechanic buddies. Question is with the spindles, would I need to get new bushings when I do the swap or just leave the factory ones in there? Any input is appreciated.
Thanks
Burt
Old Nov 25, 2009 | 06:19 AM
DriftinBlzr's Avatar
DriftinBlzr is on a distinguished road
Double check that you are getting Belltech 2102 spindles and not the S10 pieces. Also, it's a general consensus not to run anything over a 3" block. Wheel hop starts becoming an issue.
Would I need to get new bushings when I do the swap or just leave the factory ones in there?
I'm not sure what bushings you are talking about. The spindles don't have bushings.
Later, Doug
Old Nov 26, 2009 | 02:30 PM
burt's Avatar
The bushings that attach the spindles to the front sway bars and such. I looked up underneath it the other day and it looks like there is only one bushing but I may just be seeing things and it really isnt attached to the sway bars.
But I had no idea about running more than a 3" block in the back. I will definately look into that. Thanks alot
Burt
Old Jan 21, 2010 | 05:30 PM
nicycle's Avatar
nicycle is on a distinguished road
where did u order the belltech kit from
Old Jan 21, 2010 | 07:06 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default spindle
the bushings on the sway bar links are fine if your only doing spindles and 1'' coil. as long as your not changing the height by 2" on the coil or more you wont need new sway bar links with new bushings. I put on a 3.5" lift spindle and didnt have to change the sway bar link. But when I got the lift coils I had to get longer sway bar links.
theclothedcreature
Lifting Tech
Jan 22, 2010 01:37 PM
TheCackster
Nov 22, 2009 11:24 AM
eric.kimbrel
Lifting Tech
Nov 4, 2009 08:32 AM
stcdude
Jan 7, 2009 12:40 PM
furious82
Suspension Tech
May 9, 2005 10:28 PM
