SWAY BAR LINKS
I LOWERD MY 2002 S-10 BLAZER 2WDBY 3INCH SHOULD I CHANGED THE SWAY BAR LINKS
TO SHORTER ONE OR DOES IT MATTER IF I DONT THANK YOU [8D] |
RE: SWAY BAR LINKS
*Moving to Lowering Tech*
How bad do the old ones look, angle wise? Does it look like they are binding? If it does, then replace them with shorter versions (if available). |
RE: SWAY BAR LINKS
Unless its creating a binding issue like swartllkk said I wouldn't worry about it at all! When you lowered your front end did you use drop spindles and springs? If you did those in conjunction with each other maintain factory geometry!!
| All times are GMT -5. The time now is 07:32 PM. |
