whats the most common?
whats the most common drop for a '02 blazer 2dr LS 2WD? & whats the best way to tell how low its been dropped in the front? im new to this blazer forum thing so it be great if some1 would help me out?
how far do you want to go? the two most common ways are springs or spindles.
common drops are like a 2/3 or a 3/4
you can go as low as a 5/6 but it will ride on the frame pretty much most people lower the back 1 inch more than the front to level the truck out |
ok so if i got 3 inch blocks out back then i must have a 2 inch drop up front cuz it does sit even. well let me ask this...can i use a factory size shocks with the 3 inch blocks out back? or do i need drop shocks?
you can use the factory shocks, but if you have the money then i would go with drop shocks.
when you use drop blocks in the rear it doesn't change the distance the rear shocks travel therefore stock shocks are fine
if you use leafs in the rear then you would need drop shocks because you have shortened the distance of the shocks travel |
Originally Posted by packofqtips
(Post 236804)
the OP has a 2wd so he doesnt have any tbars to crank.
the idea is right though on a spindle drop drop shocks are not needed but on a spring drop they are
ok so i can use a factory shock out back but what bout my front do i need a drop shock or factory shock? (2 inch coil drop) oh and to mikeinwi, are you callin me n OP & what does that mean?
