2001 blazer w/ trailblazer pkg. 4dr 4wd
hey guys, new member, love the blazer forum.. I have a 2001 blazer w/ trailblazer package 4dr 4wd coming August 1st (thanks grandparents!), wondering a few things, it only has 30,000 miles on it so i want to do some offroad mods. 1st-does anyone have a spec sheet with suspension info, tire sizes, etc? 2nd- how big of tires can i run stock without rubbing? 3rd- Who makes a good lift kit for suspension? (i would rather steer clear of a body lift) 4th and lastly for now... is there anyway to (find) and put a ZR2 suspension on it?
thanks for anyone who helps me out!! |
RE: 2001 blazer w/ trailblazer pkg. 4dr 4wd
welcome tothe forum, if you use the search feature you will find answers to all your questions.
thanks i will try that, however the trailblazer package seems to be throwing a wrench in search functions
just try typing what your looking for skip th trailblazer part.
ok, i just wanted to make sure the trailblazer package didnt have anything to do with ZR2, am i correct in saying the 01 Blazer trailblazer doesNOT have a taller lift or bigger tires than a 01 Blazer LT 4wd?
just a fancy trim package for that year.. like the envoys were. ZR2's were the only ones with the higher ride.
Welcome from New Zealand.
welcome, the biggest size you can go with stock i belive is 30x9.50x15 but they will rub at full lock, the stock tire size is 235x75R15 as far as zr2 suspention your best bet would be to get a doner vehicle but you can get the leaf packs and stuff at a junkyard most of the time, personally i would take the who suspention including the wide stance front and read ends the zr2 rears are a little more than an inch wider and please correct me if im wrong but if you took all of the suspention from the zr2 wouldnt it be higher also? if it will be then the zr2 runs 31x10.50x15, im not positive on all my information if anythingn is wrong please correct me, hope this helpped
Zr2 is not just a different suspension, its a completely different frame.
welcome
| All times are GMT -5. The time now is 06:26 PM. |
