-   New Member Area (https://blazerforum.com/forum/new-member-area-4/)
-   -   93 Blazer Gauges go Wacky! (https://blazerforum.com/forum/new-member-area-4/93-blazer-gauges-go-wacky-73334/)
allan_bob 08-28-2012 12:49 PM
Has anyone else had a similar problem? When the key is turn on all the gauges bounce for around 10 seconds before settling down.
Rottidog 08-28-2012 02:09 PM
1st off I'd say ignition switch.
2nd you'll probably find the answer or similiar issues others have had if you use the Search feature at the top.
Jeff Hoard 09-04-2012 05:10 PM
does it crank hard because mine use to do that and then shortly after battery went out, if ur battery isnt holding voltage after u shut it off it would cause low voltage. and that could mess up ur guages soo idk its worth a try try using a multimeter on ur battery next time before u start it if its under 11 volts its prob ur battery
allan_bob 09-05-2012 10:56 AM
So far we have replaced the alternator, battery and the complete steering column. The gauges still bounce when the key is turned on.
FsTFwRd 09-05-2012 03:46 PM
My gas gauge will bounce around. But it hasn't worked in 3 years. You say it only does this for the first ten seconds of the ignition switch in the on position?
allan_bob 09-06-2012 07:21 AM
Could the ecm be going bad?
DKSDAD 10-13-2012 11:39 PM
Welcome from New York.
