Greeting from missouri.....
Hi my name is charles and this is Lil Heavy. I Always been proud owner of chevy trucks. First time owning a blazer. Owner Lil Heavy for a week and it been a blast. Had to do a tune up and more fixing poor maintance but its a blast. Have big plans ahead.https://cimg3.ibsrv.net/gimg/blazerf...f776377de2.jpg
Welcome to the forum, what are some of the plans for it?
Have a spare motor with 100xxx on it. Plan to do a turbo set and swap. The orginal motor has 230xxx on the clock and running strong but poorly taken care of. Also coilover shocks all the way around.
What are your suspension plans to run the coilovers? In stock form coilovers won't do much for you except possibly give you a bit of added payload in the rear if you crank them up a bit. I don't even know that you can fit coilovers up front without some fabrication since there just isn't room to fit them.
Welcome! Looks like you have a bit of a lift installed. Do you? What size tires?
I do have a back yard lift from previous owner. Back have leaf spring from a silverado and front been cranked all the way up. With rough country upper control arms. Running 16in rims with about 31in tires.
(Post 687054)
Coilover shocks are for daily driving and lil comfort. No plans to lift it any higher then is it.coilover will with in channel judt fin and bolt up. I seen some do a empi swap with vw coilovers. I might grab a set of long travel but no plans for off roading yet.... |
Welcome to the forum.
New member near Columbia. Maybe I'll see lil Heavy rollin around.
| All times are GMT -5. The time now is 06:31 PM. |
