-   Nitrous, Super Chargers, & Turbos (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/)
-   -   with a 5.7 supercharged engine from a 95 suburban a big step up (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/5-7-supercharged-engine-95-suburban-big-step-up-46609/)
gmoney30 07-08-2010 04:36 PM
I'm thinking about getting a engine from a 95 suburban that is supercharged, the guy said it as a little over 500 ft lbs of torque and 415 hp. Will I notice a big diifrence putting it in my 2 door 94 fullsize blazer, and is it worth it if I can get it for $1000?
wlorton 07-08-2010 05:18 PM
It all depends... If it was done right... and tuned WELL, then it could be well worth it... But it could be a CANoWORMS.. If you do get it... Pictures please :D
Rottidog 10-24-2010 11:05 PM
depends on what you have to start with... '94 blazer has what, 2.2 or a V6? Yeah thats a BIG step up but mounting, comp or not, trans, transfer case, maybe a TH700 tranny instead of (not sure what they had in '94) tranny
AJBert 10-25-2010 12:50 AM
He stated he has a fullsize so he has a 350 already.
Depending on the mileage of the engine (total and after the S/C install) and if he drove like a bat out of hell or the proverbial old lady, it could be worth it or something to steer clear. Might be worth it just for the S/C and swap it on to your engine.
Either way, you should notice a considerable difference as I believe a '94 stock ran around the mid 200's in hp. I would also be a bit concerned about the lower end as forced induction increase the strain quite a bit.
