-   Nitrous, Super Chargers, & Turbos (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/)
-   -   Banks Turbo and Stock Exhaust (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/banks-turbo-stock-exhaust-49823/)
mafiaboy01 10-03-2010 08:20 PM
Hi, I purchased a used banks turbo kit for my 87 Chevy Blazer with a 6.2L Diesel
It's old and rusted but it still in good shape. I have to change the gasket between the two half's of the turbo and some rust removal.
But my main concern is that the banks kit came with a 3 inch exhaust and their muffler.
This however was not included in my purchase.
Now I am wondering if it would be ok to connect the 2 inch stock exhaust into the turbo?
If not was is my cheapest alternative.
wlorton 10-03-2010 08:37 PM
I am not necessarily the best source, but being that you are using air from a 2inch exhaust to run the turbo shouldnt make too much of a difference, because it is exhaust driven.... But I could be completely missing the idea..... I know that a smaller pipe will cause more friction/size than a larger one.......
mafiaboy01 10-03-2010 08:39 PM
My only concern is that it would cause a lot of back pressure as its not as easy flowing as the original banks exhaust is.
I just don't want to damage the turbo with all the back pressure.
wlorton 10-03-2010 08:44 PM
Don't Quote me, but the backpressure drives the turbo, and you put a blow off valve on the other side because the pressure on the air intake side can damage the engine.... Turbos are made to be thrown pressure at ... I believe...:icon_couchhide:
swartlkk 10-04-2010 06:45 AM
I wouldn't run a 2" pipe where the original was 3". You want to keep restriction before the turbo to a minimum. I would recommend you have a 3" pipe made up to run to the turbo.
96Blazernut 10-04-2010 07:20 AM
You can run the stock exhaust with the kit, however you won't realize it's full potential until you upgrade the exhaust. And you dont need a blow off valve because diesels do not have a throttle plate. Blow off valves are used on gasoline engines where you want to keep the turbo rpm's up. I had one on my Conquest which had a turbo on it.
mafiaboy01 10-04-2010 10:52 AM
Probably just gonna hook it up like this for now then switch it when i hey some more money. I was also thinking of taking out the muffler and that should give enough flow.
