Nitrous Purge
i was wandering if anyone knew of any cheap way to make ur own purge kit...
RE: Nitrous Purge
i dunno if you can make your own. it would probably be easier to just buy the purge kit from zex or somewhere
RE: Nitrous Purge
i use a dynotunenitrous.com purge kit its only $65 and works very well
RE: Nitrous Purge
i wouldnt want a cheap purge kit...you could risk it leaking, or failing altogether and losing pressure...and i dont know about where you live, but where i live, it isnt cheap.
RE: Nitrous Purge
very simple to make your own purge kit... just get a cheap nitrous solenoid, a T joint, and conect in that soenoid right before your actual nitrous soleniod, and just do the wiring to an arming switch and a push button. and rought the purge line (can be simple fuel line) wherever you want... under the hood shooting at the winshield, or under the fender shooting out, etc. if you find a cheap solenoid on ebay it can be done for as cheap as $25-30.
| All times are GMT -5. The time now is 05:22 PM. |
