Supercharged Bravada!?!?
So I was thinking about getting the Wynjammer S/C this coming summer, I know a lot of guys have had good luck w/ the s10/extremes & blazers but I haven't found anyone that's done it on a bravada.. 1.) any major reasons why I shouldn't? & 2.) is there anything besides whats in the kit that I should look into for the well-being of the drivetrain/engine such as the spyder upgrade the wynjammer sells? 3.) is there a btr/cheaper s/c then this kit?
The S/C GM S10 4.3 Supercharger ,GM 1500 4.3 Supercharger , GM Supercharger,S10 Supercharger, |
Lots to do with it... once you get the s/c you'll need the reprogrammed ECU or get the one Al sells with/in a kit.
Then you'll need upgraded spider assy. if yours has one I'm not sure. I know my stock spider ran out of fuel at 4200 on the dyno & leaned out - a HUGE do not want! Once you get the reprogrammed ECU & upgraded spider (or marine intake with real injectors) you'll have a blast!!! But there's always more when doing things like this (wants & needs list), so keep that in mind. |
Thanks for the advice bud, I thought nobody would ever get back to me on this post haha.. I wondered about the ecu.. but it does make sense. & I was depending on doing the spider upgrade that they sell. anything you can think of as far as little things.. to make the install easier or things to watch that might go out after the install.. jw thanks again
i would think going with the marine intake would be better in the long run.
lol after my lift and tires i wanna get one. that will be a little ways down the road tho. gotta save about $3500 to do it |
Ok 1st off I'm not sure of a Bravada engine layout. That being said IF you want a Winjammer then read ALL the installation manual & from what I have Al provides a great manual, colors, pics n everything. Read it, lay it out on the floor & connect chit. get familiar with it... you'll be happy you did. It's all easy & simple & when you have to clean the MAF you'll be pffft yeah ok, np 15 mins!
Get an extra set of hands... just because it's cool to share a beer or so with friends when you add a supercharger! & it doesn't hurt either |
| All times are GMT -5. The time now is 05:14 PM. |
