supercharger
hello i have an 93 k5 blazer v8 350 5.7 and i want to supercharge it i was wondering wat is a good supercharger and if i will have to do any internals or anything else so yea anyone got some good info for me thanks
Do you have a budget? What are your expectations with the truck?
well wat iam pushing for right now is to run in the 12's i dont have a big budget but iam gonna work on it slowly like if i have to do internals i get all that done first then do the supercharger so yea iam just looking for ideas for wats gonna have to get done
Prob never going to run a 12... EVER
Originally Posted by PaulO2288
(Post 311661)
I think that if you got the weight down and had an optimal setup its possible... Maybe look into ls style swap |
Originally Posted by wlorton
(Post 311669)
He could, Also strip that thing down and gut it. I think you would want to get as much power as you can...
If you plan on supercharging an old motor... look at replacing everything that could possibly let go... Big list right? After all is said and done, you may just be better off getting a new GM crate 350 and slapping a roots charger on that. Is this a 4x4?
4 bolt main. Forged crank, and rods for starters.
yeas it is 4 wheel drive and the engine and tran only have 60,000 miles on it so yea i think it will hold car wasent beat on
Depending on how much you'll be shoving down your engine's throat you'll either need to beef it up, or you'll be just fine. If you want a heavy 4x4 to run 12's... look at building the engine up, starting with what Rogue just named off.
| All times are GMT -5. The time now is 05:24 PM. |
