-   Nitrous, Super Chargers, & Turbos (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/)
-   -   v8 swap on a 00 blazer (https://blazerforum.com/forum/nitrous-super-chargers-turbos-11/v8-swap-00-blazer-34477/)
sikblu 09-07-2009 12:45 AM
so if i wanted to swap out my v6 for a v8 how much can i use from the v6 if any an would i have to replace the trans as well? i was thinkin about adding a supercharger that was only 50 horses extra but if a v8 swap would be ezer an better how should an could i go about it? an check out my truck an nominate it for truck of the month?
Blu
1fast4.3 11-03-2009 08:58 PM
yeah man im interested in the same thing. i wana put an ls1 in my blazer.
crawl 11-26-2009 10:43 AM
http://www.allstarperformance.com/pr...LL38262&add=no
Avenger 06-02-2010 10:20 PM
i put a LS1 in my blazer and just put the v6 tranny on...even though it bolts up with no problems and with ease.... it handgrenaded on me in 4 months... id recommend a 4l80e either from a camaro or a trailblazer ss and a new valve body i put that in and it runs great
swartlkk 06-03-2010 06:14 AM
The 4L60E can be built to handle plenty of power. The 4L80E from a fullsize truck can handle more, but also uses more power. The TBSS uses the 4L70E. The Camaro came with the 4L60E.
About the swap, what direction are you wanting to go in? Do you want to keep driveability and creature comforts intact? If so, the Vortec 5.7L engine would be my recommendation for the swap. You can flash the PCM with a v8 tune, add the extra injector wires, and then rebuild the trans with high strength parts and be good to go.
AJBert 06-03-2010 08:59 PM
I'll wait to throw my .02 in as this is a 9 month old thread and the OP has a total of 2 posts.
