31 10.50 15 on stock rims and 4x4 blazer.
will those tires fit on the regular 15 inch stock rims that come on a 96 4 door 4x4 blazer? needin to know fast.. time for some new tires.. thanks
check the wheels n tires section....its a lil formula somethn bout a 15x7 + 3.5 - 4 over your rim width...I don't have direct access to it someone can correct me
This question has been answered a lot....and I mean a lot lol.
Simple answer is no. You'd be looking at a body lift with possible trimming. |
Originally Posted by Sisk
(Post 252509)
Simple answer is no. You'd be looking at a body lift with possible trimming. I'm not even sure you could get 10.5" wide tires to fit properly with 2" of lift. |
(Post 252509)
Originally Posted by okvortec
(Post 252537)
x2
I'm not even sure you could get 10.5" wide tires to fit properly with 2" of lift. as for fitting on his truck, i'd lean towards you guys knowing for sure (i haven't lifted my truck yet). i do know they would fit on the 1st gen's-without any lift (body or suspension). i was running 31's on my '84 before i lifted it. ok, they did rub, but only if i had the wheels cranked all the way and hit some bumps. but under normal driving, they were fine. |
Even with a body lift and stock wheels with 31x10.5's you will probably rub at full lock on the sway bar or frame considering the backspacing of the stock wheels.
(Post 252537)
x2
Originally Posted by 1baddblazer
(Post 252889)
mine isnt 4x4. mine is 2wd. I have 3.5" lift by fabtech and 31x10.50 on 15" rims my front wheel sticks out 1.5 inches farther...still had to trim inner fender quite a bit...
but he's also running that with a 2" body lift, for a total of 8". plus he's runnin' around with 33's. i just want to be able to run 31's and not hit.
