-   Off Roading (https://blazerforum.com/forum/off-roading-25/)
-   -   4x4 won't work? (https://blazerforum.com/forum/off-roading-25/4x4-wont-work-101712/)
Boostedreed 05-23-2020 09:25 PM
4x4 won't work?
I've replaced the actuator an cable. The vacuum seems to be pulling the cable but still no 4x4. I'm replacing a vacuum hose right now but still why isn't it working
christine_208 05-23-2020 11:31 PM
Is it that the front axle is not being engaged? Could it be that the transfer case is not engaged?
Boostedreed 05-24-2020 10:15 AM
The transfer case seems to engage tha front since shaft does
christine_208 05-24-2020 11:13 AM
If the cable to the front axle is being pulled by the vacuum, then perhaps the issue is that the gear that is engaged could be stripped.
I think you should be able to confirm if the front axle is engaged or not by lifting the front tires off the ground and checking if rotating one wheel causes the other rotate the othet direction.
Boostedreed 05-24-2020 11:38 AM
Yea I've tried that nothing happens
Boostedreed 05-24-2020 11:39 AM
What's that mean?
christine_208 05-24-2020 01:19 PM
The gear that can get stripped is #10 in the diagram below. I've seen it go by several names. One is Front Axle Disconnect Gear.
(https://nemigaparts.com/cat_spares/e...t/06/tt06-089/)
https://nemigaparts.com/img/catalogs...a_2/263133.png
Boostedreed 05-24-2020 08:38 PM
I got it working actually n it works good! It was one of the vacuum hoses I replaced. It had a cut in it
christine_208 05-24-2020 11:07 PM
Yeah! Aren't those easy fixes the best!
Boostedreed 05-25-2020 03:01 PM
Yea I changed the actuator an cable n then a line I'm glad I was being dumb pulling on things I probably would of went through changing the transfer case too n everything else lol
Boostedreed 05-25-2020 03:03 PM
https://cimg7.ibsrv.net/gimg/blazerf...9fc1da489c.jpg
Is this a transmission cooler or power steering i took it off a jimmy thats a lil newer then mine
christine_208 05-25-2020 05:37 PM
That looks like the PS cooler. On an AT equipped Blazer, the transmission cooling is done by connection to the radiator.
BritishColumbiafishing 11-11-2020 03:51 PM
t case motor I bet ya. Easy cheap fix
