-   Off Roading (https://blazerforum.com/forum/off-roading-25/)
-   -   94 s15 jimmy lift ?'s (https://blazerforum.com/forum/off-roading-25/94-s15-jimmy-lift-s-30662/)
GMCMUDDER 05-17-2009 08:28 PM
well im new to here so whats up ppl.....well i have a 94 jimbo and im getting ready to lift...thinking of doing a 3" body lift and a 2" rough country suspension lift or maybe just the 2" suspension lift with 31' BFG MT any suggestions?
mikeinwi 05-17-2009 08:32 PM
you only need 2" of lift to fit 31's however you achieve the 2" is purely up to. i would suggest doing some searches and get all the info you can on the lifts ur considering and weigh the pros/cons of each kit and buy whatever will suit you best.
GMCMUDDER 05-17-2009 08:41 PM
OK...ive read about the RC lift on here and every one has always talked bad about ball joints and all has any one had good remarks....or are ya'll just beating the crap out the ride and causing them to go bad?
mikeinwi 05-17-2009 08:48 PM
i thinks its more the cv's that get worn down with this lift not so much the balljoints, now i cant speak for each person and how they treat there blazers, but IMO you can get the same aount of lift by just cranking ur stock tb's. if i were in your shoes i would just go with the 3" body lift that way youll still have pleny of room for ur 31's and youwont be going through cv's like water. heres a good post about the 2" suspension lift gremlins and things to expect from the lift>>> https://blazerforum.com/forum/lifting-tech-44/2%22-suspension-lift-gremlins-26616/
