96 Blazer Mudd Tires
What Size Tires Would Be Best On A 96 Blazer 35 Or 38? Its Got A Stock Lift To. What Size Lift Would I Need For 38's?:icon_speaker1::icon_speaker1::icon_speaker1: :icon_speaker1:
2" fits about 31's i do beilve, u can fit 30x9.5 on stock hieght
you want to fit 35's or 38's on a S-series Blazer?
never gonna happen unless you go SAS. nj4x4blaze has 6" SL & 2" BL, and he's running 33's. why you wanna go so big? (please don't give a lame reason) |
x2 on what Chris just said. No way you're fitting 35's or 38's on an S series truck without a SERIOUS amount of work (ie turing it into a monster truck...to the point where it's not even a Blazer anymore). You can just squeeze 31's in there with 2" of lift. There are a couple of people on the forum that have 33's with 9" of lift, and they still had to trim.
Who gave you the idea you could go so big? Also, please be sure to read all board descriptions. This should have been posted in the lift tech or tire board. |
You can fit 34's with a 6" lift and 2" body lift, 2" shackles and tbar crank. But you still have to hack away at your fenders. You can fit 35's and 38's with the lift above but you have to remove the front fenders, ditch the hood and remove the rear bumper corners and hack away at the rear fender corners until the rubbing stops.
Im Just New To The Off Road Stuff. I Just Want A Lift And Tires That Will Make Heads Turn. And i Want A Cheap Way Of Doing It.I Mean 35's Would be Good.
I Also Want A Big Enough Lift That I Dont Get Mudd In The Cab. It Sits To low To Do Anything Right Now. I Wanna Play In Ponds Not Ditches.
Originally Posted by TylerNormand
(Post 349241)
I hate to say it, but Dave is completely right (he speaks from experience). You better be ready to fork out an easy 5000$ for a lift that will allow you to fit 33's (you can forget about 35's and just get that idea out of your head right away).
That's not even including tires. Plan for another 1500-2000$ on tires alone. I'd budget anywhere from 7000-10,000$. Is it out of your price range yet? lol..cause it's definitely out of mine..otherwise I'd be riding high right now. Sorry man, but you bought the wrong truck if you want that big a tire. There are plenty of members that play in puddles on a regular basis. It's not impossible, but it sounds like you have no idea the shear amount of $$ time and work involved in doing this kind of build. I agree with Dave's suggestion and go full size if you want a serious offroader, but by the sounds of it you don't have a lot of cash flow. It's not a great sport to get into if you don't have the money to float it. You need serious amounts of cash just to build your rig, then you need the cash to be able to replace everything you break (and be damn sure you will break stuff). Also, please don't double post. Use the "edit" feature if you have something else to add to your post. Double posting is against the forum rules. |
just so you guys know its been done a friend of mine has a s10 that he performed a SAS on and is running 44's....it is an insane truck...just thought id share
| All times are GMT -5. The time now is 04:34 PM. |
