beach sand = stuck!
ive only ben stuck in the sand once and that was because the rut i was in split and went in two different directions but i wasnt stuck that bad. i was just up to the bottom of therim.how did you burry it like that?
jimmyboy
jimmyboy
for sand driving you should always have a shovel, air compressor, and dont drive too slow as you sink. you can even run down to 10psi in bad conditions. always drive in a high gear and not a low gear.
ORIGINAL: blazinrebel
definitly should have aired down, but i dont think that bfg a/t's are good for sand anyway. where is that at
allterrains are better than mud tires or more aggresive tires in sand as you want to try and float on sand and not dig in....if ya air down you can get through most things...
