Go Back  Blazer Forum - Chevy Blazer Forums > General > Off Roading
Reload this Page >
blazer body lift lets see em!
Community
Search
Old 03-20-2012, 03:39 PM
kwedge243 is on a distinguished road
Default blazer body lift lets see em!
hey guys got my blazer and im looking into body lifts and i know how bad they look with the gap and all if there over a cuple of inches. i was looking a a 2 inch, i would prefer to get that then the rc 2 inch because of price. but anyways can i get a good look at the gaps in the wheel-wells and bumper area! thanks!!!
Old 03-20-2012, 04:03 PM
tibby's Avatar
Default .
Yeah, I can get you some pictures a little later on tonight. If you don't like the gaps, they sell gap guards just for this occasion. But I like the gap as the truck is easier to work on. But you know the gap is big when you can reach your hand through the wheel well and touch engine components easily. Also, I can touch a lot of the lift blocks on my blaze fairly easy too. And the bumper gap is little. It is hardly noticeable at all.
Old 03-20-2012, 04:48 PM
warthogdriver's Avatar
What i did for the gaps in the rear was get a floor mat from menards for 2 bucks cut it in half drill the wheel well and use the plastic panel tree things to keep them there
Old 03-20-2012, 08:31 PM
IrvJr is on a distinguished road
I used the ORD body mounts and got their 1" spacers to go with. Hardly noticeable.
Old 03-20-2012, 09:22 PM
Rottidog's Avatar
1st off it would help knowing what year blazer you have (1st or 2nd gen).
I got my blazer with a 1st gen, 3" body lift installed already from the previous owner. 1st gens had a 3" BL available while 2nd gens (mine) only had 2" as the max. That being said they couldn't install the bumper brackets, so my bumpers are at stock height & the rest is 3" higher.
With some fender & front bumper trimming, 1.5" T-Bar twist & inch longer rear shackles I can run 32" x 11.5" tires on Pro Comp Rock Crawler 10" wide rims.
I have some aluminum checker plate I'm going to get powdercoated & place in the bumper to body gaps as well & undercoat the frame to hide the nastyness lol.
I'd love to get some automatic running boards that deploy & then hide. Not that I need them, but passengers sometimes do because my blazer is 3" or so taller than a stock ZR2.
<edit> With a good BL, properly installed - what gaps are you talking about? The body should be up 2" higher & you'll see more frame, that's all. The bumpers should be raised along with the body because of the brackets that should be included. As for the gaps in the fenderwells between the body & frame, look up Gap Guards. I got a front & back set for around $100 that are made for a 2nd gen blazer.
It does look sorta silly seeing a truck raised up & you can see right through the other side above the frame etc. Gap Guards fix that issue.
Old 03-21-2012, 12:33 AM
tibby's Avatar
What are you talking about? It's not like your bumper will line up snug like stock height. Bumper brackets only get your bumper up so far. I still have space in between my bumper and grille. Every body lift does this.
Old 03-21-2012, 07:36 AM
I have a 99 4dr everything is stock. Once I get the cash Imma buy a body I think. Now I like the bulldog style lifts can I do the 2In body and and a 2in rc up front?
Old 03-21-2012, 01:08 PM
Red 96''s Avatar
Really? The bumper brackets that came with my PA lift brought the front bumper right up to the grill, just as it would be without the BL. Not sure why yours would be any different.
Old 03-21-2012, 02:48 PM
tibby's Avatar
Default .
I'm not really sure either. I have the same pa body lift you do and have a space between mine. It isn't that big of a space, but a space nonetheless.
All the body lifts I've seen have had a similar space right there.
Old 03-21-2012, 02:49 PM
tibby's Avatar
Default .
Here are the gaps in the wheel wells OP.
Front:
Front:
Rear:
Rear:
Quick Reply: blazer body lift lets see em!
