blazer's off-road ability
Hey guys, i was jsut wondering what kind of off-road ability a stock blazer has. I know that i have been through some nasty snow and was very impressed! howevor i have not been through any mud and was just wondering how well they fair. i would suspect pretty well, since so many off you all have been off road. do they compare to jeeps?
RE: blazer's off-road ability
I don't do off roading trips just to offroad, but my Bravada did very well getting out to my tree stands, crossing small creeks, as well as getting back to where I shot my deer two years ago. Worked quite well! My Rainier gets through the same stuff. Its a bit better in the mud though with the wider tires and better ground clearance (stock for stock).
nothing compares to a blazer jeeps are nuttin but heeps.
I know blazers are good offroad, they have very even weight distribution that helps considerably with 4wd.
However...regarding jeeps: ORIGINAL: fla_blazer4x4 jeeps are nuttin but heeps. As for your question though, Blazers need a little bit of modification to compare to a jeep out of the box. But I feel with a minor lift to clear some bigger/better tires, they'll take a jeep on most trails :D |
Agreed with what has been said above. I actually went out on a stock truck run last year with a group of 4x4's from my school. I ended up having the most stock truck and made it through the same stuff and more without getting stuck, the guys in the jeeps and lifted fullsize trucks were impressed with the abilities of the stock blazer with worn highway allseasons. Now I have slightly larger BFG AT's and have yet to put it to the test off road, but once the snow melts I will be out there trying it out.
Does great off-road.
Stay away from deep water. Don't go any deeper than the bumper. Trust me. |
Question on that:
I was reading in a Land Rover hand book for offroad driving (quite a good read if anyones interested) and it said whenever attempting a water crossing you have to keep moving and at a constant speed. Something about how the water flows around and under the truck, and the air in the engine bay remains relatively calm, but once you stop or slow down too much the water backs up and you flood. It also mentioned that water entrys are the most dangerous part (makes sense...the nose dives mostly). Any thought's on the technique for a deep water crossing? I just avoid the ponds myself, but this is good knowledge to have! :D |
I did good until I found a hole in the river, and the water was suddently over the drivers corner of my hood... :D
On the plus side, as long as you don't stop, you don't get water inside... At least, I didn't. |
ORIGINAL: fla_blazer4x4 nothing compares to a blazer jeeps are nuttin but heeps. |
I loved my jeep, but like previously stated I hated driving it on the road. Very unstable and if you think that we get bad gas mileage, then take a long trip in a wrangler on 32s.
| All times are GMT -5. The time now is 03:49 PM. |
