easy/cheap modifications for a less stock look?
Okay here is the deal I have a 2002 s10 blazer 4 door and i want to look more off road (which is where im going to take it) but right now it looks to stock for my liking so what are some easy things I can do to make it look more like an off road truck? thanks for any replys!!
Grab some cold beverages of your choice and some snacks and start reading its all been covered a million times on here!! Check out the builds section for sure there's some nice rigs in there with tons of ideas!
Yep. Surf through the builds section. There's tons of great ideas on what you can do. Rex's build is a great one for lots of ideas to customize your ride.
Well thank you sir as is yours!!
Start with debadging. Its free
Pull the front air dam. Paint the wheels. Remove the badges like newguy mentioned.
plati-dip the rockers, crank the t-bar, spare tire carrier, off road lights,
okay thanks guys! im thinking off debadgeing it because my trim is all worn out/sun faded on the outside so i might try that! also i have two small fog lights i may put on top of it. But for the rims im unsure on how hard it would be because they are alluminum sooo how would i go about doing that?
scuffing them down really well and use plasti-dip and if you dont like the plasti-dip will rub off
No scuffing needed for plastidip! If you dothat and don't like it and pull it off your left with scratched up paint:(
| All times are GMT -5. The time now is 04:14 PM. |
