-   Off Roading (https://blazerforum.com/forum/off-roading-25/)
-   -   just turned up t-bare and wount sit even (https://blazerforum.com/forum/off-roading-25/just-turned-up-t-bare-wount-sit-even-64088/)
nick'sblazer42 10-16-2011 08:36 PM
could us sum held dont no if i need shokes or what?
NVANZEE 10-16-2011 09:06 PM
you need to adjust one side until its even
Clyde 10-16-2011 09:59 PM
what?
NVANZEE 10-16-2011 10:35 PM
Originally Posted by Clyde (Post 467403)
what?
took me a while to understand it too. I believe it says "could use some help, dont know if i need shocks or what"
xgiovannix12 10-16-2011 10:48 PM
took me a while to read it
i think he cranked his tbars and now the trucks not level :icon_shrug:
he might have a saggy tbar
nick'sblazer42 10-17-2011 08:04 AM
how could i fix a saggy tbar
pettyfog 10-17-2011 09:18 AM
I love a good challenge.
Was the truck level before you started. did you count the turns each side.
Did you disconnect one side of the sway bar first? Only need disc. 1 side.
I have no idea where to go from here.. but first thing is I would disconnect the sway bar {be careful!} and then adjust in small increments each side till it sits where you want.
PS: bad shocks {one side} will affect height while driving .. not while sitting. Otherwise you couldnt depress them by hand.
nick'sblazer42 10-17-2011 01:06 PM
its the lower A-arm 1 sits higher but the truck is level and sway bar is connected
pettyfog 10-17-2011 06:44 PM
I suggest you read my post again and answer those questions and try to understand how sway bars work.
Unless you have {1} a bent frame, OR {2} a bent lower control arm..
In which case.. {1} junk it, {2} get one from a wrecker
To put a point on it.. if you jack up one side's torsion bar, then the other side will also lift because of the sway bar. That is why you disconnect it before the TB lift or drop so that each side is bearing its own weight. When you have the front end height where you want it, THEN you reconnect the sway bar.
Got it?
nick'sblazer42 10-18-2011 05:06 AM
its all good now
