this makes no sence
IM NEW AT THIS FORUM THING BUT OK BLAZERS HAVE 4 WHEEL DRIVE TO GET U OUT WEN UR STUCK BUT IT TAKES 5 TO 10 FEET TO LOCK IN SO HOWS IT SUPPOSE TO WORK
RE: this makes no sence
um you pop it into nuetral man and it should engage instantly.
Mine works as soon as I shift the lever.
Turn off your capslock |
Its an automatic thing on blazer's I don't understand why you would think it takes a distance to engage!! Also if you type in caps lock it means your yelling no need to do that!!
ORIGINAL: thegr81 Its an automatic thing on blazer's I don't understand why you would think it takes a distance to engage!! Also if you type in caps lock it means your yelling no need to do that!! And !!! means your making a statement which you seem to do alot. |
sometimes mine takes a while to engage...but i have an older blazer that was beat on ages before i got it lol. But once its warmed up it will pop in and out no problem. Maybe theres somethin wrong with your t-case?
If he has a slow vaccum leak it will do it too. Best thing to do is put it in 4 wheel before you go in the mud
| All times are GMT -5. The time now is 04:14 PM. |
