off road mods
Hey guys I'm starting to make my 03 blazer more off road capable am was wondering you guys had any recommendations On tires, lifts, I've got some welding experience so I want to build my out bumpers and roof racks, but just in general any thing helps thanks!
If it's going to be an off road only build and you want it to be as capable as possible, I would start looking through some of the solid front axle conversions people have done. There are definitely easier way to lift the truck and get some form of clearance, but a solid front axle is going to be the most capable, in my opinion.
Originally Posted by lazyboyjake
(Post 648473)
A solid front axle is going to be a lot less prone to breakage. The way these blazers are built uses independent front suspension so you have to deal with joints in each axle shaft as opposed to a single, solid axle shaft for each side. When you start angling those joints beyond the factory angles they tend to break a lot easier, which means no 4WD. But it all depends on how much you're looking to spend, how high you want it, and what you're going to be doing with it.
(Post 648476)
It typically takes a few months to a year of planning and buying parts here and there along with the time it takes to install it. And it will be costly. I've never done one, but from what I've read it can be anywhere from $2000+ after everything is done.
No I ment just the axle. But ya I figuerd it will ake about that
The axle itself ranges depending on what axle you get and where you get it from.
