What year is your blazer? Does your c/v axles bolt to the transfer case? Mine just slide in.
Originally Posted by DonL
(Post 699842)
Mine just bolt right up. I believe it's six bolts on each. |
Whoa, makes me Jones for a 6 inch lift!
(Post 699847)
Not like we have any other options for a lift that size for our trucks, anyway |
So, not much done tonight. Had a few errands after work. I did get a decent work light, so hopefully my pics will turn out better from now on!
You have to remove the factory steering center link: https://cimg3.ibsrv.net/gimg/blazerf...332c882826.jpg After removal: https://cimg5.ibsrv.net/gimg/blazerf...8fa5ed1f5d.jpg Now you need to cut out the factory stabilizer bracket: https://cimg5.ibsrv.net/gimg/blazerf...0c9a23ad18.jpg Like so: https://cimg9.ibsrv.net/gimg/blazerf...0e1e448aab.jpg Quick question: does y'alls trucks have anything mounted to that bracket in the above pics? Mine didn't have any type of stabilizer there, I'm wondering why it's even there. Now you can bolt on the new center link: https://cimg8.ibsrv.net/gimg/blazerf...53f1c81231.jpg In the instructions, you're supposed to cut parts of the control arm pockets. The pictures are absolute trash, and I can't tell where I'm supposed to cut. I'm skipping that part from now, I'll wait till I start bolting the control arm drop brackets on, and see if that makes it more clear |
Originally Posted by cleburne red
(Post 699852)
Quick question: does y'alls trucks have anything mounted to that bracket in the above pics? Mine didn't have any type of stabilizer there, I'm wondering why it's even there. ... |
Man, the instructions on this kit are absolute garbage. Can't tell hardly anything from them. They give you a rough idea of what's supposed to happen, but the rest is up to you to figure out!
I started off tonight by installing the front lower control arm crossmember. This requires a little bit of cutting to fit: https://cimg3.ibsrv.net/gimg/blazerf...1a0d1f097a.jpg Please ignore my finger lol. This is the passenger side control arm mounting pocket. Laying on your back looking up, feet towards the front of the vehicle. The driver side is done the same way. Here is the crossmember fully mounted: https://cimg9.ibsrv.net/gimg/blazerf...1e49ca8f05.jpg There is a "link" that goes between this crossmember and the steering center link: https://cimg3.ibsrv.net/gimg/blazerf...95a26535cd.jpg This thing pissed me right off. First, the threads were a little messed up. One of the "ball joint" type ends threaded into the sleeve fine, the other I had to clamp in my vise, and turn with a crescent wrench. Also, the way the bolts are oriented, you can't even get a ratchet on them, much less an impact. Wrenches all the way. After all that, I mounted the passenger side diff drop bracket: https://cimg2.ibsrv.net/gimg/blazerf...859adb4fc7.jpg The picture in the instructions doesn't help much. The bracket that sticks off of it goes towards the front of the vehicle. This is what the steering stabilizer attaches to. (Note how the bolts are angled. Think you're gonna get an impact or ratchet on that?) Steering stabilizer mounted: https://cimg6.ibsrv.net/gimg/blazerf...8d0c65bdd9.jpg https://cimg9.ibsrv.net/gimg/blazerf...8420614415.jpg Had a hell of a time getting that stabilizer on, also. The rubber donuts on the shaft end of the stabilizer were too thick, and I couldn't get the nut started. Had to shave them down a little with a knife. They look like they are over compressed right now, but that was the only way I could get a full nut on the threaded shaft. That's probably all for tonight, next is a little cutting on the diff, and installing the other two diff brackets, and then somehow getting the diff back in place. |
Well, we messed up today guys. Had to cut the fins off the diff for clearance. Got a little carried away:
https://cimg7.ibsrv.net/gimg/blazerf...ead61f4ab9.jpg On my way to home depot now for jb weld. Probably not the best idea, but it's definitely the cheapest lol |
Whoops! :eek:
Could you get some 90 degree angle aluminum extrusion and with some sealant screw it over the opening to seal it? |
Possibly. I've got some quick set jb weld, I'm going to gradually build it up to cover the hole. If it doesn't work, I can always pull one at the junk yard
| All times are GMT -5. The time now is 03:56 PM. |
