Shackles & D-Rings
Hey all,
Was wondering what happened to the Synergy shackle& D ring kit? I don't have tow hooks factory, and I plan on a body raise. Will the body raise affect placement of these? I removed the bumper cover Thanks! |
Not sure if they still carry them or not but you can do the same thing for about $40 yourself! I just bought the tubes from harbor freight and then drilled them to fit where the factory hooks were located I also drilled them to fit the two bolts that hold the skid plate as well for a total of four bolts holding them in place. Mine were mounted inside the frame rails so the body lift had no effect on them. The other thing I did was to ditch the D rings they came with and added some bigger/better ones.
Is there a certain diameter I need to shop for, or are all these typically one size?
all are usually 2 inch. Made to fit trailer hitch receiver
