Suspension lift
Would anybody like to tell me where they got there lifts from...i want a 3 or 4" lift for my 98 4dr blazer, i cant find one anywere for under 1300 dollars and its getting on my nerves. plz help
RE: Suspension lift
Ah, welcome to the world of lifting on the cheap. Ok, about the only option you got here is the following, but as I've warned countless people this can cause premature front end wear, so here we go.
To start with get a body lift. 2 inches right there, fairly easy to do, no front end wear,and it costs under $300. Next, and this is where you can get wear on the front end if you dont grease things,tighten your torsion bar adjustment bolts about 5 full turns for about 1.5" or so of lift in the front. For the rear get an add-a-leaf kit or buy or build some shackles for cheap. If ya do it right you should be well under $500. For more details on what is involved use the search feature on the forum or shoot myself or Jigg a PM. |
RE: Suspension lift
so theres no way to find a suspension kit because to me that would be a whole lot easier. if not how long do you think it would take to do all that stuff?
RE: Suspension lift
Well you other alternative is the superlifts 2" lift kit, but to me thats a waste of $$ and you can just do what Rcars2 said. But if you really want a suspension lift check out summit racing, synergy offroad, superlifts.com and so on. You can always do a body lift too which is easy.
RE: Suspension lift
I originally wanted a Zr2 blazer, but just ended up getting a 2 door blazer with 4wd. I've also been looking at lift kits, was about ready to go buy a body lift. But i'd rather go with a suspension lift, even though they are much more expensive. But im also interested in cranking the torsion bar(s) if that doesn't do any harm to your truck?
RE: Suspension lift
[/align]i belive cranking the torsion bar more than 2 inches puts wear on the front end but dont quote me. i asked a similar question when i first registered in the forum |
RE: Suspension lift
ya, we need a sticky for lifts!!!!
RE: Suspension lift
cranking the tbars is a suspension lift. its just apretty way of cranking the tbars and new springs in the rear. they both cause suspension wear. i would go with the body lift
RE: Suspension lift
i know this is going to sound like a newbie question, but where are the bolts to crank my torsion bar? 97 blazer 4 door 4wheel drive
RE: Suspension lift
ORIGINAL: blazerboy124 i know this is going to sound like a newbie question, but where are the bolts to crank my torsion bar? 97 blazer 4 door 4wheel drive its the same for all 4x4 s10's |
| All times are GMT -5. The time now is 04:25 PM. |
