what did you break today
what happened to your blazer today what did you do and how much are you in for $$$$$$ and how did you do it
Roy 95 S-10 blazer |
Last 3 weeks:
Tranny $600 to fix, with shift kit, tranny temp gauge and royal purple ATF. Intake gasket $50 Idler arm $45 Front brake flex lines $60 Bent upper control arm and ball joint $60 Going SFA at the end of march to get rid of this IFS ****... |
Mine started up :/
Well nothing broke but i have a wheel bearing going $100 and need a new idler arm(moog) $60.
water pump and themostat went yesterday all good now 60 buck later
wheel weights fell off have to get my wheels balanced...
my cat went yesturday so i have to get a new one
radiator started leaking on the drivers side but luckly i work where there used to be a GM dealership and there is a junk blazer in the back lot all tore up so i got that and bought the thermostat $15 but the fuel pump is on the way out..... the fun never stops
dude, i had to spend a thousand bucks on a new pump and labor. $469 for a full pump is why to much:(
thermostat went the other day! $15 and a little work later and its all good!
