what do i have?
well i am looking for a spool for my blazer, it is a 91 2dr 4wd with a 4.3 in it. i need to know what rearend i have and also what front i have. do they make a spool for the front? im thinking about welding the front and rear diffs up, but since i see spools are like 85 bucks, i would go that route instead. this truck is a 100% offroad truck only, so spools or being welded it will be fine
Fastest way is through the RPO listing in the glovebox.
Here are some of the ones off of a 2000 list (don't think it changed at all year to year):
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G80 Rear Axle: Positraction, Limited Slip
You could also look it up on one of the many RPO code listing sites: Regular Production Option (RPO) Codes
sorry for not being more specific from the get go. thanks for the help guys im gunna check around for a spool and what not. if i find a spool that fits a GM 7.25" would it matter if it is in the front or rear? did GM ever put a 7.25 in the rear? the more i think about it, im not gunna do that to the front of this truck, especially not yet....may cause to much problems with the turning....
I think they're the same. I looked up some info on it and here's what I found.
Do you have IFS?
Vehicle Model Year
S-SERIES PICKUP, & BLAZER 79 & UP
(OEM) GM 7.25" FRONT RING & PINIONS
TEETH RATIO
40-13 3.08
41-12 3.42
41-11 3.73
41-10 4.10
GM 7.5" & 7.625" RING & PINIONS (rear)
TEETH RATIO
OE 41-15 2.73
T/L 40-13 3.08
OE 40-13 3.08
OE 42-13 3.23
OE 41-12 3.42
T/L 41-12 3.42
Try here for rear end stuff.
http://www.wayfindersband.com/powertrax.html
Do you have IFS?
Vehicle Model Year
TEETH RATIO
40-13 3.08
41-12 3.42
41-11 3.73
41-10 4.10
TEETH RATIO
OE 41-15 2.73
T/L 40-13 3.08
OE 40-13 3.08
OE 42-13 3.23
OE 41-12 3.42
T/L 41-12 3.42
yeah, i have the torsion bar suspension. i have the no-slip in my 2wd ranger and ABSOLUTELY LOVE it. it is awesome onroad and especially offroad, maybe ppl have thought i was 4wd when im only a 2wheeler, lol. as for that link. i see a powertrax for 99.99, but how do i get more info on it? there isnt a link anywhere, that i see atleast...
Here ya go....
They claim their LockRight is a little noisier than the powertrax. The lockright is about 95.00 cheaper. Whats nice you don't have to mess w/ pinion/ring gear backlash. It's a drop in and play.
