Wheel spacing
I know everyone has already asked this but my answer was not found after many hours of searching, I have a 1998 4dr blazer stock suspension, About to order a 2.5" RC suspension lift with a 2" body lift, I already have the 31" tires in the shed, my question is do I need wheel spacers to keep the tires from rubbing, also will it look stupid without the tires being off set, I really want to keep the factory wheel.
ul need a 1" spacer or ul rub at full lock on the sway bar and frame and even ur fender. u still may need to trim ur fender a lil.
:icon_playing: |
lifting blazer
i have a 1998 4dr blazer is there a lift that will work with the stock independent suspension on the front end or do i have to swap it to a solid axle or any other suggestions
i was wanting to put a 2-3 inch suspension lift and 2 in body |
Originally Posted by bman
(Post 511769)
i was wanting to put a 2-3 inch suspension lift and 2 in body But for the price of the 5 or 6 inch ifs lift, you can do a solid axle swap, so that is something to think about. |
