Will my winch be strong enough?
I recently got a superwinch x3 rated at 4,000 lbs for free and was just wondering if I should even bother putting it on the blazer or not?
Thats an ATV winch. General rule is you want a winch that is rated double than the weight of the truck. Blazers being roughly 4000lbs a 8000lb is the smallest you can use.
neo nailed it. you'll be needing a 9000 lb winch.
you could use a snatch block to double your pulling power, but it's gonna be working @ max capacity every time you use it. better to sell it, and use that free cash towards a bigger winch. |
(Post 407397)
you could use a snatch block to double your pulling power, but it's gonna be working @ max capacity every time you use it. better to sell it, and use that free cash towards a bigger winch. or a lift and bigger/better tires so I'm less likely to get stuck :icon_wink: |
