2000 Blazer Interior Lights won't work when opening door
Interior lights will work when you turn the switch on in the cab but will not work whe you open the driver's side door or passenger side door It is a 2 door LS model Any help or suggestions would be great Thanks
RE: 2000 Blazer Interior Lights won't work when opening door
not that i claim to know much about cars, but did you try that little dome override push switch? when its out i believe the interior lights come on when a door is open.
ORIGINAL: flyinquack not that i claim to know much about cars, but did you try that little dome override push switch? when its out i believe the interior lights come on when a door is open. You could also check to make sure the switches in the doors are functioning correctly. If they're stuck in, that would make the switch think the door is still closed. http://img187.imageshack.us/img187/8...rswitchew7.png |
Thanks for the info. the override button was sticking, not allowing it to come out all the way Thanksagain Jody
thats whats wrong with mine
| All times are GMT -5. The time now is 01:54 PM. |
