4x4 into Zr2
#21
I want your axles...I want them so bad.
#22
If I ever take them out, I will let you know Wolfpack.
#23
Haha thanks
I just wanna put in lockers...and it's tricky for the 7.625...and impossible with the aluminum front diff [>:]
#24
is the zr2 suspension not interchangeable? i mean, if you were able to find one in a bone yard, could you snag the front suspension and rear axle?
#25
You could use the rear axle, but that is it. The front suspension will not fit on a regular 4x4 frame.
#26
No the frames are different between zr2s and non zr2s. The sr2 frame is bigger and the mounting brackets are different aswell. Its not worth the work for 3 inches. You may aswell just get the rough country 2 inch lift and do a b.l. Then you would have plenty of room for 31s 32s or even 33s with trimming.
#27
I am struggling to find Flares for a 2000+ 4Door as well, i looked at that link above and it only brought up a trail blazer.Thats not what i need. What does this guy have?(SEE PIC) (i found this on the Net. Here is what he wrote: ” Body Lift – Bushwacker flares. Manik F guard. PIAA 520’s. Safari rack. Smitty nerfs. 30950R15 Michelin. LTX AT’s on MT classic II’s.I got on the bushwackers website and they said that only the front 2peice set would fit a 2002 4 door, They only one varity fits the 4door blazer. That sounds odd to me. I need to find a way to get some legit flares on a 2002 4 door. I am losing hope on the net.
#28
The only company I've seen that makes flares for a 4 door is EGR. I've got the link saved somewhere...I'll see if I can find it.
But as far as them being 'legit' or not....
Edit: Got em. CLICK ME. EGR apparently does not make these anymore though, which is why the link I posted on the first page of this thread no longer works.
wanabmudder00
12-12-2013 12:45 PM
RickBlazer
06-23-2011 04:59 AM
poepoe624
01-10-2010 11:48 AM
Boiler_81
12-02-2008 10:04 AM
