94 interior lights
I have found other posts about the interior lights on the 2nd gen blazers but I was wondering the bulb on the first gen for the sun visor bulbs. I cant find them anywhere they are 30mm long and 5mm wide. If you guys need a pic I can gladly get one. Thanks
RE: 94 interior lights
arent they 194?
are you wanting LED replacements? or just regualr 194 bulbs? |
no they look exactly like glass fuses and im wanting to change to all LED's
I have been looking everywhere still no luck here's pictures and it has 14V01A-BLC on the side of the bulb's base
[IMG]local://upfiles/9278/8E749B6912C24CD7B69D1992761D5DA0.jpg[/IMG] [IMG]local://upfiles/9278/772D07E8385045D98965517EE576F520.jpg[/IMG] |
There was a post on here giving all the bulb numbers for every bulb on a blazer
If you use the search function Im sure you will find it. I tried searching but I can't seem to find it...maybe you will have luck? Edit: This topic should help you a lot! https://blazerforum.com/m_83242/tm.htm Also here is the bulb on ebay Ebay link The bulb is 211-2 |
Thank you but I found it!! http://www.weisd.com/store2/SUNSR12V.html
The one I found that is a LED is 31x6mm the bulb I have now is 32x5mm it is close enough to work I think [sm=smiley20.gif] |
| All times are GMT -5. The time now is 05:49 PM. |
