-   -   98+ Front End Conversion Kit (https://blazerforum.com/forum/paint-body-interior-39/98-front-end-conversion-kit-10352/)
Cassus Kagal Jan 13, 2010 06:17 PM
I have a question. Is it possible to make this change -without- changing the bumper and such out? Just changing the grille and headlights I mean. I went to a scrap yard today and found a 97 grille and held it to the 98 model, and it looked like it would fit exactly. I couldn't tell for sure though as I couldn't get the hood to the 98 open to look inside. Any insight? The main change I'm wanting is to the newer headlights, as I personally like them a bit better.
old skool luvr Jan 13, 2010 06:48 PM
^^^you don't need to change the bumper Cassus. but you do need to change the rad support. read back through this thread, everything is discussed as to what would be needed.
just remember to cut off as much wiring as possible (gives you more to work with on your truck).
Big O Jan 22, 2010 04:57 PM
I have a 97 blazer, and I am wanting to convert my front end, but I am confused. What is a bumper rad? and a bumper cassus?
dimone545 Mar 20, 2010 10:31 AM
wow are you serious? Cassus was just the guys name that was being responded to....LOL he was telling the guy that he didnt need to change out the bumper.
Rad support is the radiator support.
97MikeBlaze May 24, 2010 03:46 AM
LoLz!^^
Yeah, the headlights on the 97 Blazer i have are hideous to me lol
88cougar May 29, 2010 01:28 PM
I'm confused so I need a core support for a 98-04 blazer headlights, park lights, bumper cover for 98-04 blazer, Grille and push clips? I have a 95
Also u have sealed beams now what wiring do I need to convert. Lmc makes a heavy duty wiring kit would that work?
kickme005 Jun 23, 2010 11:31 AM
will a Bravada front end work? i want the bumper with the spot for the fog light and the spot for the hooks? can i just change the bumper mounts and put the Bravada bumper leave my grille?
GreekPower Jul 2, 2010 01:38 AM
this is one of my biggest mods I want to do to my 96. Is the rad support swap needed? if so does it bolt in or weld in? how complex is changing the rad support?
kickme005 Aug 19, 2010 07:21 AM
after taking off your fron end(lights, grille, bumper, markers, rad core support,an ur raditorar) then once u install the 98-up core everything will then go in. and u need a wire harness for the lights yes u can save a couple hundread dollars going to the junk yard
old skool luvr Aug 19, 2010 10:16 PM
it sounds like you're getting the hang of the search function kickme.
it also sounds like you might have your swap done already. did you do a build thread for it?
