Adding homelink
Old Oct 19, 2007 | 04:03 PM
cain45's Avatar
cain45 is an unknown quantity at this point
Default Adding homelink
My 2003 Blazer doesn't have homelink. So I purchased a new overhead center console. The console has the 2 lights, moonroof button and now 3 buttons for Homelink.
3 of the wiring harnesses are interchangeable. The other 2 are not.
Anyone know if it's possible to make the new one work or how to wire it?
Old Oct 19, 2007 | 04:06 PM
Default RE: Adding homelink
According to my references, all you need is power, ground, and the dimmer signal which may or may not be up there already. Power and ground should be there.
Old Oct 19, 2007 | 04:19 PM
cain45's Avatar
They are not there. When you look at my current connectors there are 3 pins inside. The new one has 5 pins inside. Also where you plug in the compass is small and only about 6 pins across on current one, new one is way wider with 9-10 pins across.
RetroBlazer
Mar 28, 2012 09:19 PM
Whittaker
Jul 17, 2007 08:00 PM
cherryred4x4
Apr 2, 2006 12:29 AM
burcham
Nov 22, 2005 05:21 PM
ajmeehan
Engine & Internal
May 23, 2005 11:41 PM
