Back window hatch glass won’t stop squeaking!
Old 11-17-2018, 08:36 AM
USBlazer's Avatar
USBlazer is on a distinguished road
Default Back window hatch glass won’t stop squeaking!
2002 4 dr* the back hatch glass refuses to stop squeaking while I’m driving and it’s driving me nuts. For now it’s gotten so annoying that I put the truck in neutral and pop the hatch open while I’m driving and hit the dome light override. I’m getting to the point of where I’m going to go get thick one sided foam tape to put around the edge of the glass to stop it but I would prefer a more stock look than that cob job, is there any way to tighten the latch since I assume that’s why it’s not closing tight enough to avoid that squeak?
Old 11-17-2018, 01:19 PM
christine_208 will become famous soon enough
Look at the hinges and lubricate them. When I've done that and then move the pins of the hinges so that the heads of the pins are at the end of the hinge, it seems to go away. Doing this might at least lead you to an easier solution.
Good luck
Old 11-29-2018, 07:33 AM
USBlazer's Avatar
Good luck
thanks
Matthew Anglin
09-08-2018 06:27 AM
ddgdmg
10-07-2014 03:00 PM
Jace1217
02-22-2012 03:55 AM
alleyoop333
04-08-2011 04:45 PM
michaeljwyo
09-29-2009 11:31 AM
Quick Reply: Back window hatch glass won’t stop squeaking!
