Blazer front end on an 05 Jimmy?
Hello,
Been doing some research and I have found there are no HID's for Jimmys... So, I would like to use the blazer HIDs, found all over... I know the bumper, grille, and lights need to be switched, What else am I missing? mounting the same? is it direct switch? Please advise Thanks |
You will need to swap the rad support as well, and I'm not sure on the wiring.
DonL,
I thought they were the same rad support for 05 Blazer and 05 Jimmy, LMC Truck has them as the same part number, unless i am mistaken. what would be different about the wiring? |
I could be mistaken, I might be thinking of the older second gens and the newer second gens. I thought the light fixture mounts where different, I might be thinking the difference between the none fog lights and fog lights.
I would wait for someone else to chime in about it, I'm second guessing myself right now lol... |
Fairly certain the 98+ Blazers and Jimmys have the same light wiring. The 98-00 Jimmy Envoys and 98-01 Bravadas have the extra fog lights built into the bumper molding.
Everything else sounds like it will switch just fine. |
Originally Posted by DonL
(Post 704942)
Red, you got it.
Mounting brackets for the bumper are different, But they are bolt on.
I think it is possible, I will update with what happens |
The bumpers for the Jimmy/Sonoma/Bravada are 2 pieces.... an inner steel bumper, and a plastic cover that clips to it.
I have fooled around with changing my bumper with an Envoy or Bravada, but haven't committed. Grab some pics, if you can. I'd like to see what you find out. |
For second generation stuff the only time you have to swap the radiator support is if you go from 94-97 to 98 and later body style.
