-   -   Body lift install (https://blazerforum.com/forum/paint-body-interior-39/body-lift-install-26314/)
NVANZEE 01-05-2009 07:28 PM
Body lift install
Im installing a PA body lift this weekend. Is there any tips or tricks i should know of before installing it.
WolfPack 01-05-2009 10:23 PM
RE: Body lift install
1. use the BDS instructions
2. dont forget to take off the ground strap on the passenger side firewall, by the hood.
3. dont try to remove the filler neck till after you get the lift pucks in. Disconnect, but do not remove till lifted...much easier
4. The directions go through a pretty lengthy process of relocating and dropping the (+) dist. block beneath the battery. Mine had plenty of slack and did not need to be even loosened.
5. The body mount bolts will be on pretty tough, mine came off easily with 2' of pipe on the end of a 3/4' drive ratchet (I didnt pre-soak with PB blaster)
Those were the big ones for me...I'm sure others have found a few tricky spots as well :)
Take before and after pics!
NVANZEE 01-05-2009 10:35 PM
i plan on having the bolts soaking in pb all week starting tomorrow. What kind of thread lock should i use
WolfPack 01-06-2009 02:27 AM
The PA kit comes with some red locktite
NVANZEE 01-06-2009 07:10 AM
ok thanks
NVANZEE 01-10-2009 10:59 PM
im in the process of re-installing everything after the lift. Did you have any problems with the radiator hose inlet on the left hitting the belt.
98jblaze 04-02-2010 07:46 AM
i don't know what bds stands for i need the instructions to do a body lift just don't know what bds stands for please educate me thanks
TRX 04-02-2010 11:42 AM
These are the instructions I used for my 98 LT.
http://www.bds-suspension.com/pdfs/9228.pdf
This is the BDS main site.
