-   -   Body Swaps (https://blazerforum.com/forum/paint-body-interior-39/body-swaps-63634/)
nktidwel Sep 30, 2011 08:04 PM
Body Swaps
I know this has been discussed, but for some reason I didn't find what I wanted to know.
What I do know: My 90 FSB has almost completely rusted out. The body mounts are shot. There are no rocker panels. There are lots of holes in the floor. I can look to my left in the back seat and look outside (not using the window). When I close my fuel filler door, rust jumps from my wheel well. Oh, and my taillights are barely staying mounted.
Options:
Find a donor Blazer: been looking 6 months...
Put a pickup cab on it, add a cross member, and build/mod a bed.
So what is the newest cab I can put on there with minimal work? It also needs to hold at least 3 passengers without interfering with the 4wd shifter
Preferebly like this setup: Backseat
It is a 90 FSB 350, 4wd, gone carbureted
CenTexBiker Oct 1, 2011 02:09 PM
why dont you find a blazer (2nd gen) and put it on your frame?
there are write ups from people who have done that
nktidwel Oct 2, 2011 09:51 AM
I am looking for almost anything at this point. About to convert it to a pickup.
nktidwel Nov 26, 2011 06:15 AM
Picked up an '84 body yesterday. Not to self do not use a Ranger with a 3.0 and 5sp...
nktidwel Nov 27, 2011 11:57 AM
Ran the VIN, it is an '86. Started tearing apart my existing body, and found that the body mount brackets are shot. Rusted to heck. My existing body is kind of just sitting on the frame. Where can I get all new brackets?
nktidwel Dec 2, 2011 05:54 PM
Yesterday got the new "new" '86 body off the trailer. On the 90: Already pulled the front end off. Today, pulled the topper off the back (why are there bolts that are hidden?) The whole thing was siliconed to the body. Now it is not reusable (had to take a crowbar to it, and broke some fiberglass in the process). Also pulled both doors off. Tomorrow's plan is to cut the bolts off holding the body to the frame, pull the seats out, and maybe pull the windshield.
nktidwel Dec 6, 2011 09:47 AM
Anyone know where I can get some new body mounts (not the bushings, the parts that are on the frame.
nktidwel Dec 10, 2011 08:33 AM
Body may come off today. Need to remove the E-brake cable and the Speedo cable.
nktidwel Dec 11, 2011 06:09 AM
https://fbcdn-sphotos-a.akamaihd.net...78796851_n.jpg
nktidwel Dec 11, 2011 01:13 PM
Pulled the wires inside the old body, and pulled my steering column, as the one in the donor is damaged. I knew the dash was welded, but I didn't realize @ the windshield, it is still easy to pull wires are pulling the 5 bolts. Oh yeah, everything that you see on the firewall has been removed.
