RE: Changed all interior lights to LEDs.DIRECT REPLACEMENT.
ORIGINAL: dimmuborgir6nik6 Looks great, can you give installation tips, for example taking out and installing the sun visor lights, front and rear dome lights and under dash lights? At first I was thinking of getting neon lights for under the dash, but now I can just pop in some blue LED's into the factory whites. For the light in the glove box, I wanted to make things a lot easier for me, and I just popped out the whole entire glove box. It would be impossible to install that LED through the tiny hole in which the glove box light shines through. So I simply took off every bolt on the glove box. Now let me say, that that small 194 bulb stays on for the whole time that you are taking out the glove box, so when you finally do have the glove box out, you need to hold that small button that shuts off the light bulb for quite a few minutes in order for the light bulb to cool down. Once it has cooled down, then remove the light bulb, and s |
What about this?
http://frickinbrite.com/catalog/prod...roducts_id=362 Will they fit under the dash? |
Those are the same exact ones that I have underneath my dash, only difference is mine are HID white.
Good enough, atleast I know they'll run since we both have the '96.:D
Yea, plus they're really bright. It's 25 high power LED's. lol
Great information, sounds very easy, especially with a lot of information.
I'm just changing out my map lights, both lights under dash, and both dome lights. The glove box doesn't matter to me since I never open it. Thanks though! |
No problem. Post some picks up when you're done.
Definitely will. I'm ordering 4 map lights, 2 dome lights and 2 dash lights now.
Now to get the chrome racing pedals and give them a little shine with the lights. |
Sounds good.
Alright, got my bulbs in the mail today.
I just need to find a dremel to sand down the bulb housings inside the map lights. I taped sand paper to a drill bit and tried sanding down the plastic but it took too long. Also, the bulbs under the dash, do you unscrew the entire bulb? Or just pull the bulb out? I was having some trouble trying to unscrew it. |
| All times are GMT -5. The time now is 01:08 PM. |
