clear corner lenses
What would be the easyest way to replace the yellow corner/turn lights with clear lense/ yellow bulb lights? Can I get at them from inside the wheel wells? Or under the bumper maybe?
Question #2: How hard is it to wire fog lights? Could I just stick them in the tow hook openings and splice them into the head light wires? Or would that short out the system? My silverstars are 65 or 55watts a pop @ 12.8 volts....thats like 5 amps so if I put in 50watt fog lamps it might spike to 10 amps.... I wonder if its a 10amp fuse or a 7.5?.....
EDIT: PS I have a 2000 2dr 4x4.
Clears are EASY to install. I just did mine about 3 weeks ago. Here is how to do it:
1. Remove the tabs that hold in the headlights.
2. Remove bulbs from headlights.
3. Once headlights are removed, remove bulbs from turn signals.
4. To remove turn lenses, turn them away from the truck (Ex. If removing passenger side swing out to the left).
**It may seem like you are going to break them...but don't worry they won't break!!**
5. Change bulbs to amber.
6. Remove grill. (This aids in the re-installation of headlights)
7. Install new lenses.
8. Re-install headlights.
9. Re-install grill.
10. Test lights and you're done!!
Took me about 30 minutes to do mine. It's an easy upgrade the dramatically improves the exterior appearance. As far as the fog lights go I have NO idea.
^^^ WTF? dude, it seriously takes like 30 seconds to switch out turn signal bulbs on our model blazers. all you do is remove headlights (by pulling 2 retainer clips out), then reach down and remove bulb on turn signal housing. you dont need to unplug the headlights or remove grill. its seriously freakin easy as hell.
