Plastic Push Pins for S10 and Blazers
Old 09-18-2017, 07:56 PM
MountainDew's Avatar
MountainDew is on a distinguished road
Default Plastic Push Pins for S10 and Blazers
Does anyone know where I can look at all the different push pins with part numbers so I can order some new ones. If not I guess Ill match them up best as possible. Im mainly looking for the ones that go to the door seals at the bottom of the doors, front and back, also rear wheel plastic shields that go on the frame I need those to. If you look on ebay you can buy packs of 50 and 100 for cheap only problem is making sure they are the exact size. This is the closest I have found so far. http://www.srfast.com/catalog/gm.pdf
Old 11-14-2017, 04:47 PM
N. Jensen's Avatar
Check with LMC.com .... I found them on their a few years back, then ordered them on eBay for a buck or two.
kennybopaloo
09-02-2010 10:51 PM
Nemo1991
07-05-2010 01:07 AM
zedartwo
11-20-2009 05:15 PM
kross
05-16-2008 08:54 PM
Quick Reply: Plastic Push Pins for S10 and Blazers
