Cracked Dash, Yes I searched
Like I said... Yes I searched and came up with very little. I'm just trying to figure out which road to take here. Find a new one in good shape, slap a cover on it, or??? Open to sugestions. Any input is appreciated
My 86 had a cracked up dash pad and the po glued on some kinda cover and now the cover is pealing and cracked id jest buy a new one
new = permanent fix.
cover = cosmetic fix. platic weld = suggestion. (not a good one, but suggestion none the less) |
New= from LMC? If I do that I want a whole new dash not one of those pads. LMC is hard to navigate on a phone
IMO.... pull one from a wrecked blazer/jimmy, lots of good ones kicking around and much ccheaper
i meant new to you. yours year will be easy to find replacements for.
sorry for not making that clear. 69chevelle is spot on |
Originally Posted by 69chevelle
(Post 402176)
my local JY are only charging $50 fo rthe dash in a 2nd gen. |
Yeah Ill probably end up doing that eventually. Ill probably just throw a dash rug on it for awhile. Finding stuff like that down here has always proved diffivult
First I've heard of a cracked dash in a 2nd Gen. Seems as all the auto manufacturers have pretty much figured out the dash cracking problem in the last 20 or so years.
Every corner of where the defrost grill sits is cracked. On one side all the way to the speaker grill.
