-   -   Dash Removal (https://blazerforum.com/forum/paint-body-interior-39/dash-removal-45702/)
Qumodo 06-13-2010 08:54 PM
Dash Removal
alright so i need to remove my dash to replace the heater control switch and wiring to my radio. does anyone have any helpful tips to remove the dash with as much ease as possible? i have searched the forum and the web and have turned up nothing. any help would be great.
vas 06-24-2010 11:38 PM
Hi,
I have a 99' Chevy Blazer, it was fairly easy for me. You'll need a nut driver (10-32 I believe) and a dash removal tool (makes it easier). The only problem I ran into, was having to angle the dash to allow me to remove it as a whole (I had to lower the steering wheel and shift my car into neutral -- shifter was in the way--).'
Good luck.
vas 06-24-2010 11:39 PM
I found this video on youtube, hope it helps.
http://www.youtube.com/watch?v=L28MkE81MOo
84BlazerS10 06-25-2010 12:45 AM
If he has an 89 like his signature says the video wouldn't work.
vas 06-25-2010 02:24 AM
Ooops, my bad. In that case: I found this over on another forum, hope it helps
http://www.s10forum.com/forum/f62/89...emoval-273151/
Re: 89 s10 dash removal
it's been about 5 years or so since i pulled a gauge cluster out of a 1st gen, but i'm pretty sure you start by removing the two screws in the bottom of the ac/heat control panel. be careful when you pull this panel loose. it won't come all the way out without a LOT of work, which is unneccesary for this project.
then you'll have to take the headlight switch panel loose. get a light and look around. you'll see some thin metal nuts holding the gauge cluster down over some plastic studs. remove these and don't loose them in the dash. next, remove the gauge cluster trim (look up from near the steering wheel and you'll see the screws holding the trim in).
i don't remember if you have to drop the steering column, but if you do, loosen the two large nuts holding the column bracket up (you'll have to remove some of the trim panels first that cover the lower area below the steering column). then look on the column near the cluster and you'll see a metal clip attached to the column trim that has a string attached to it. push the clip back and off. the clip and string are what move the gear indicator needle in the gauge display if you have an automatic.
after all this, you should be able to just pull the gauge cluster straight out toward you at least several inches. you'll have to reach behind the cluster and remove the clip holding the spedometer cable to the back of the spedo. (i think it uses a clip, but it may screw on and off).
the gauge cluster will pop out of a single large electrical circuit connector near the bottom of the passenger side on the back of the cluster, if i remember correctly. then you just gotta twist the little plastic sockets loose to get the bulbs out. make sure to replace with the CORRECT bulbs, not just any bulb that will fit the sockets. too large (amperage-wise) of a bulb will melt stuff eventually.
btw, now is a great time to take some needle nose pliers and pull the inner cable out of the spedometer cable and grease it. they all eventually start squeaking anyways, so may as well fix that while it's apart. in the past, one of the older guys i worked for at a small shop had me coat the inner spedometer cable with vasoline on a s-10. he says it lasts a long time and won't dry out when you slide the inner cable back in, the end that goes into the gear in the transmission has a square end on it, so you'll have to turn it while pushing to get it to go all the way back into the gear.
reassemble everything and take lots of pics and together we'll pretty much have made a How-To thread. if not, i'll just do it later when I get around to changing all my bulbs.
Anybody that's done this more recently can feel free to add to my description or correct me if i missed something or got something wrong. Like i said, it's been at least 5 years, probably closer to 8 or 10, since I've done this myself.
