-   -   driver seat question (https://blazerforum.com/forum/paint-body-interior-39/driver-seat-question-72969/)
trixspix Aug 13, 2012 11:00 AM
I need to replace my driver seat and was trying to find out if I could replace my non power seat with a powered one the wire harness connector under the seat has 6 pins with wires coming to it but only 2 wires going out to the seat belt. is there a way of figuring out if a power seat would work or not.
97cherryblazer Aug 13, 2012 12:37 PM
What year is your blazer and what year did the seats come out of?
But yes any powered seat will work with your wiring harness but if you are trying to wire 95-97 seats into a 98+ blazer you will have to do some modification.
Check out my thread HERE
trixspix Aug 13, 2012 06:29 PM
oops my bad I thought I included some of that info this is a 2001 blazer LS at this time dont have donor vechicle because I am just at the stage of seeing if it could be done. will start looking for seat now.
robertfireye Aug 15, 2012 10:55 AM
Power seats will work fine for that. I just had a bench seat and I popped some leather power/heat/mem seats in its place on my 2000 LS Blazer. The harness you see is a full power harness, the only two being used are for the seatbelt sensor and a ground. You can do the passenger seat too, as there is a full harness for it under the carpet behind the seat. I had to cut the carpet opening for the torx bolt open a little and fish it out. Its very worth it though.
