Emblems
Old May 16, 2007 | 10:58 AM
Dabber's Avatar
Dabber is an unknown quantity at this point
Default Emblems
I am looing to shave my Blazer emblems of my truck and I know how to do that with all the reading I have done herebut my question is when I bought the truck from the dealer they put one of their Dealer labels on the back tailgate.How do I go about removing that one without scratching the paint??
Old May 16, 2007 | 03:25 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: Emblems
Your Blazer will look so much better after you shave all the emblems. I bought some adhesive remover and I sprayed it on the blazer, chevrolet, and the black protectors at the bottom of the doors. I also sprayed the vinyl dealer label on the back of my car. I let everything soak for about 10 minutes (I wouldn't do it for much longer). Then I used a black, non stick spatula to scrape the emblems and vinyl labels off. It worked wonders. Then I used some wax and waxed over where the emblems. Easy.
Old May 16, 2007 | 08:02 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: Emblems
When I took the PARAMOUNT CHEVY badge off the back, i used a heat gun. I held it there for aboutten seconds and then I pulled the badge right off. I then took some Bug &Tar remover to get the rest of the adhesive off, then waxed it. I never considered taking the door trim off. If it wasn't there there is not telling how many dings I would have.
Old May 16, 2007 | 10:16 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Default RE: Emblems
For adhesive i would use mineral spirits, alittle goes a long way. You cant get it at most autoparts stores.
Old May 18, 2007 | 10:39 AM
Dabber's Avatar
Default RE: Emblems
Thanx guys. My buddy has a heat gun so I will borrow it off him sometime. Eurogold I don't have the trim on mine just the emblems. So no worries about that one.
Old May 19, 2007 | 01:04 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default RE: Emblems
I have removed a few of the dealer decals before and using a soappy water solution and letting it soak, then taking a razor blade very carefully and a very low angle should take it off, then just wax and buff the spot. Just go slow and easy with the razor blade. They also make plastic razor blades that look just like the metal but dont scratch as easy and do about the same job.
Old May 23, 2007 | 11:01 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Default RE: Emblems
Would a blow dryer also work, instead of a heat gun?
Old May 23, 2007 | 11:12 AM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: Emblems
Yeah, they are kinda the same thing.
Old Jun 7, 2007 | 09:04 AM
Psychropod's Avatar
Default RE: Emblems
Cool. I bought a bunch of black Chevy bowtie emblems off Ebay, and I know they'll look a lot better than the stock puke-yellow emblems that came with the truck.
Crew, I still have couple of questions, though...
1) My truck is 11 years old. When I remove the emblems, isn't it likely that the paint under the removed emblems will be a different color than the rest of the truck? If so, is there a cheap way to hide this? (If not, I may just decide to have the entire truck painted again anyway.)
2) My truck has "LS" emblems located on the upper part of the door. Can I easily remove these also without scratching the paint? I found these cool "SS" emblems that match the bowties, but it would look stupid if I put those on without removing the "LS" emblems first.
Old Jun 19, 2007 | 07:55 PM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
Default RE: Emblems
how do you get the bowtie off of the grill? like Pyscropod, i wanna ditch the puke yellow one, it just doesnt go too good w/ black. and if i just spray paint it will it hold up ok?
