-   -   Exterior Window Moulding (https://blazerforum.com/forum/paint-body-interior-39/exterior-window-moulding-15612/)
blazinloud 12-23-2007 10:16 AM
Anyone have any problems with theirs comming un-glued?
my passenger side kinda does an arc like this (
just unglued in the middle.......any easy fixes or should I just get speedy auto glass to fix it when I get my windsheild replaced?
Chevy Lover 12-23-2007 04:10 PM
RE: Exterior Window Moulding
What moulding are you referring to? The drip rail moulding, the outer belt moulding, the glass run channel or the door opening weatherstrip moulding?
And what year was that?
blazinloud 12-23-2007 05:17 PM
its a 98......its the moulding on the outside of the passenger window along the bottom
mdehoogh 12-23-2007 05:25 PM
mine does the same thing. on the drivers door, if the window is down, you can just pick up the molding. its basically justsitting there. on mine, its not quite up against the glass. kinda arc'd like you said yours was. its never given me any trouble so i havent bothered fixing it.
swartlkk 12-23-2007 08:32 PM
I had this same problem on all 4 doors of my old Bravada. There are little rectangular lugs on the inside edge of the molding itself. Then there are slots in the sheetmetal of the door that are supposed to accept these lugs. I was able to reach down inside with a thin screwdriver and pry out the top of these slots allowing the molding to catch better. Never had a problem with them again. Be careful though, the glass is right there!!
blazinloud 12-24-2007 03:06 PM
k I'll check that out, thanks guys
